tunneled-vlan
gre tunnel
Defines the VLAN that connected clients use to route GRE tunneled traffic within their respective WLANs
Syntax
tunneled-vlan <VLAN-ID>
Parameters
tunneled-vlan <VLAN-ID> Specifies the VLANs associated with this GRE tunnel
  • <VLAN-ID> – Specify the VLAN IDs. Specify a comma-separated list of IDs, to specify multiple VLANs. For example, 1,10,12,16-20.
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)# tunneled-vlan 10
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#show context
 gre tunnel testGRETunnel
  peer 1 ip 192.168.13.6
  native vlan 1
  tunneled-vlan 1,10
  native tagged
  dscp 20
  failover interval 200 retry 5
Related Commands
no Removes the GRE tunnel settings based on the parameters passed
